I am cleaning out things I don't use. I absolutely love this trailer. It is perfect for a 914. I have a 5000lb winch on the front. So it is easy to load & the tilt deck works perfectly. The car sits perfectly when the door sits just in front of the wheels. Great balance & you can open & close the door with no problem. Only considering selling as I just don't use it enough. Have 2 girls in College & the start of the new year coming. So generating some extra cash. I have had this trailer 3+ years. I replaced the deck about 18 months ago. All pressure treated lumber, I also redid all the wiring for the lights. I used a roll on bedliner on the frame. Only thing you could do is hook up the electric brakes. I never bothered as I don't haul anything heavy with it. Plus I like towing it with smaller rigs. Most of which don't have the tow brake setup anyway. In the pics it is hooked up to my crew cab which has it sitting way to high. So it is a little tough to see the tilt. There is a pics with it tilted & one without. It does have hydraulic so it doesn't slam up or down.
$1600 to world members , $1800 on CL
