I am doing the 5 lug conversion and need to remove the old rear wheel bearings. I've heard this can be an extremely tough project. Can anyone recommend the best tool or process to press these out?
bdstone914
Jul 28 2014, 06:17 PM
QUOTE(Sfreeman615 @ Jul 28 2014, 04:49 PM)
See if you can rent for free a bearing puller set from you local auto parts store. I bought a HF set on sake for $ 45. Did you get the hub removed?
76-914
Jul 28 2014, 06:19 PM
I've beat them out with a 3lb sledge, pulled them with 1/2 threaded rod and used a press. #1 is the press, hands down. The press requires that you remove the trailing arms where as the other 2 do not.
Sfreeman615
Jul 28 2014, 06:52 PM
Yes the control arms are off the car and the hubs are off as well.
JawjaPorsche
Jul 28 2014, 07:55 PM
If your control arms are off here is the best way to remove and install.
IIRC, I used a 1.25" x 3/4" black steel reducer with a 3/4" nipple screwed into one end to make the piece that goes between the bearing and press.
malcolm2
Jul 29 2014, 11:19 AM
Sounds like you are making progress Steve. Keep plugging away.
Clark
Cap'n Krusty
Jul 29 2014, 01:02 PM
An installation tips. Apply pressure ONLY to the outer race when installing the bearing into the control arm. Install the bearing cover once the bearing is seated. Apply pressure ONLY to the inner race when installing the hub. That means you need to support the inner race as you press in the hub. Be sure the hub is filly seated in the bearing before installing the stub axle.
The Cap'n
74914LE
Jul 29 2014, 05:33 PM
I made a tool using a piece of 3/4" pipe with reducers at each end. The end that goes against the bearing is something like a 2" to 3/4" reducer. It fit perfectly in the opening on the back side of the trailing arm. I put a pug on that end, and it helped center it in the bearing hole, so that when it was struck by the 2lb. hammer, it stayed in place. All it took was a couple of taps, and out it came. To install, I have always used a piece of large threaded stock, with large washers and nuts attached, to pull the bearing into place by turning the nuts. Always works great for me. Good Luck!
JamesM
Jul 29 2014, 05:42 PM
QUOTE(JawjaPorsche @ Jul 28 2014, 05:55 PM)
Which is why if I ever need to do mine, I am just going to drive over and let Eric do them
I really need to buy a press one of these days!
