QUOTE(75porsche914 @ Jul 30 2014, 03:14 PM)
QUOTE(bdstone914 @ Jul 29 2014, 09:29 PM)
Here is the Pelican article that references the part number. I found it for sale but the picture shows it with the two black tubes that the 914 switch uses. It is a vw part number. Not sure if the picture is wrong.
http://www.pelicanparts.com/techarticles/9...tric_washer.htm.
This article has a picture of the right switch.
http://914electric.wordpress.com/2011/04/2...er-switch-hack/Thanks so much Bruce, I always appreciate your support.
I found the same articles last night and ordered the ghia switch, identical part but half the price. Porsche no longer makes the 924 switch, and could only find a brown switch on eBay and would need black to match my car
If you got it from CIP1 double check the wiring (compare it to your original switch). Pin 2 and 3 are likely reversed. Don't ask how I know.
And for what it's worth, I couldn't make that switch work to save my life (even after the reversed wiring discovery). Kept blowing fuse 8. I worked on this problem for WEEKS!
