Just got my 96 mm AA P&C kit for my short stroke 66 mm motor that I'm building. After doing research, I'm looking at the 86a Web Cam as I've always been a higher-end power and don't care much about torque. Using 1.8 heads, opened up with bigger valves (dual springs too), 40 IDFs and POSSIBLY ceramic coating the tops of the pistons and combustion chambers and running 9.5:1 CR.
Question - Since the 86a is a top-end happy cam, should I match it with shorter intakes or stay with the longer intakes to help balance it? Pros/cons? I'm not worried about in-town drivability and would rather it be spirited on backroads and at auto-x's.
Thanks for your input!
Randy
