FS: My Project 1973 914 Porsche 2.0 setup for LS Engine
1999 Camaro LS1 Engine 84,000 miles Runs Good
1989 911 Carrera complete 5 Lug front and rear suspension with Axles, Rotors, Calipers
4 Fuchs Wheels and New Tires 2-16x8 225/50-16, 2-16x7 205/55-16
Renegade Hybrids Basic LS-Series Conversion Kit:
Renegade Custom Motor Mount Assembly
Custom Rear Transaxle Set Back Blocks
Billet Aluminum Adapter Plate
One Piece Billet Flywheel and Starter Ring Gear
Stage Two High Performance Nine Inch Pressure Plate
Kevlar High Performance Nine Inch Clutch Disc
Custom Pilot Bearing
Throw Out Bearing
Water Pump and Fittings
Billet Aluminum Coolant Inlet/Outlet Plates and Fittings
Custom Aluminum Filler Neck
In Line Filler "T"
Coolant Outlet "Log"
Custom Alternator Bracket
Gates Green Stripe Hose
Alternator Belt
All necessary hardware
Renegade Hybrids 914 Complete Cooling System:
With custom all aluminum radiator, dual high performance Spal fans, dual relays, thermostatic control switch, harness and all necessary sheet metal.
LS-Series to 914 Complete Custom Fuel Injection Harness by Renegade Hybrids
LS- Series Computer Programming by Renegade Hybrids
Radiator Hose Kit by Renegade Hybrids
Custom Front Valance by Renegade Hybrids
914 Rear GT Spoiler by American International Racing
914 Front and Rear Trunk shox kit by Camp 914
Rear Axle Joint Flange Adapter Set Porsche 901 / 914 Transmission to larger 911 Carrera Axle Assembly by Patrick Motorsports
Wheel Bearing Rear Porsche Carrera by Patrick Motorsports
Rear Axle Control Arm Box Reinforcement Set by Patrick Motorsports
Axle Spacer Inner And Outer 914 / 901 To Carrera Drive Axle Assembly This Item Is Designed For Use With 5 Lug Carrera Axle Flange by Patrick Motorsports
914 Chassis Reinforcement Stiffening Kit:
LS1 Headers:
$8000.00 takes it all
All the above items will not be sold separate
Car is located in Los Angeles local pick-up no shipping
Call Donnie for more info 323-547-7806
Will consider some trade need a Chevy Vortec 8100 L18 Engine with Transmission, wiring harness and computer
