Hi all
Im restoring a US 1976 2.0 with a 1973 2.0 engine (not sure how that happened but hey). Im in the UK and these are as rare as hens teeth.
Ive decided to retrofit a standard FI system (currently gathering the relevant bits).
My engine builder has suggested a Web cam - WEB #73 262/262 duration 0.426 lift which I believe is correct.
Any ideas on what pistons I should use? The 73 engine has bus pistons which are in good shape but if Im going to the expense of rebuilding then I feel I should put something better back in.
Im not looking to build a hot rod just a nice reliable fun motor.
My engine chap is suggesting Keith and Black pistons (96mm). Would that work or are there better options?
thanks
Andrew
