QUOTE(RoadGlue @ Aug 2 2014, 10:24 AM)
I'll use whatever Web Cam recommends. I don't see why Raby's lifters are required if he's using Web Cam's cams built to his spec. The hardening coating/process is exactly the same, so nothing to stress out about. ;-)
I can say from my experience that is not true.
I ordered a Raby cam & lifters, messed with the geometry for months and decided that the cam I got would not work for me.
I ordered a webcam instead, installed it and am running with it.
The difference I noticed was that after weeks of turning the engine and measuring valve geometry (albeit with less than full strength springs), there was zero noticeable wear in the coating on the raby cam.
When I received the webcam, just measuring it with a micrometer marred/disturbed the coating more than the raby cam.
So I dont know if it makes a difference in the long term use of the two cams, but the final coating on the Raby cam did NOT appear to be identical to the webcam coating.
I still have a perfectly new raby cam & lifters on a shelf gathering cobwebs.
I chose to buy webcam lifters with the webcam, and did not try to use the raby lifters.
