QUOTE(Mike Bellis @ Aug 5 2014, 12:11 AM)
If one light works, it's not the switch or the Hi/Lo relay. Spin the fuse in the fuse holder . If the other lamp will light, there is power at one side of the fuse. The wire goes directly from the fuse to the lamp.
Mike, you win the prize tonight! Indeed that worked. However my flashers still aren't working
I've had my turn signal switch out lately (wiper switch woes) and that coincided with the flasher loss (evidently the right side higbeam was merely a coincendetial and un related problem).
I've tried a new flasher relay and even swapped out a known to be good hazard switch....I still wonder at the column turn signal switch in reference to the loss of hazards. Are they or can they be related?
