Are there any smart solutions out there for fitting the 3-bolt 2.0 manifold to the 4-bolt 1.7 heads (with the engine still in the car)?
/Lars S
dlee6204
Aug 4 2014, 05:04 AM
You use 1.7/1.8 intake gasket as a template and you drill the extra holes. You then need to clearance the outer holes so there is enough room to install a nut. I have some pictures of this as I did the same thing. I'll post them up when I have the time.
larss
Aug 4 2014, 05:08 AM
QUOTE(dlee6204 @ Aug 4 2014, 01:04 PM)
That sounds fairly simple, thanks !
/Lars S
stugray
Aug 4 2014, 07:20 AM
When I comared two sets of intakes (short for a 1.7 & long for a 2.0).
The diameter of the intake bores did not match.
I may be wrong, but I dont thnik you would WANT to mix them up.
larss
Aug 4 2014, 07:28 AM
QUOTE(stugray @ Aug 4 2014, 03:20 PM)
Not sure what you mean with short and long intakes (?) but the intake bore in a 1.7 head is narrower and will not match the 2.0 manifold bore (without some machining).
Lars S
Dave_Darling
Aug 4 2014, 08:01 AM
Why do you want to use the 2.0 pipes on a 1.7 motor?
--DD
larss
Aug 4 2014, 08:11 AM
QUOTE(Dave_Darling @ Aug 4 2014, 04:01 PM)
--DD
Sorry my bad explanation, it is 1.7 heads but 1911cc engine. I hope for some extra air from the 2.0 TB and extea fuel from the green injectors.
Lars S.
