Downerman
Aug 4 2014, 01:29 PM
So I feel an e-brake is important. I have the larger SC callipers up front and the smaller ones on the rear. The rears do not have the e-brake levers so I'm guessing their early 911's. I understand some 914-6 ones will work but hard to get. Wondering if something like a 914 calliper (Rear of course) with a 914-6 rotor might work as 80% of the breaking is up-front. I was suggested to research a "line lock" but don't know squat besides in the past feathering an-ebrake has sometimes been my saving grace in some unusual situations. Any other options or suggestions?
Dave
73 914 Renegade SBC
SLITS
Aug 4 2014, 01:41 PM
1.) Purchase Eric Shea's aluminum reproduction 914/6 rear calipers
or
2.) Purchase a set of 914/6 rears and send them to Eric for his magic
or
3.) Use a standard set of 914/4 rears (need to cut a couple of mm off the circumference of the 914/6 rotor or have the 4 lug rears drilled for 5 lug.
or
4.) Use a rock, angle cut 4X4, or anything that blocks the wheel.
or
5.) Use the 911 rear set up with the drum brake parking brake (requires fabrication of brackets & such)
mskala
Aug 4 2014, 01:47 PM
QUOTE(SLITS @ Aug 4 2014, 03:41 PM)
Elliot Cannon
Aug 4 2014, 01:56 PM
That's what I did. They work fine and I expect they'll last a long time.
(To paraphrase Pratt Whitney).
