JB620
Aug 4 2014, 08:32 PM
So... I'm no mechanic but I'm thinking it's not supposed to look like this! I just recently brought my car back to life after many years of sitting. After driving a bit then parking I noticed a drip and this is what I found. Just what do you think is going on here??? Thanks in advance!
Mike Bellis
Aug 4 2014, 09:25 PM
Looks like undercoating... Thick, sticky, weird pattern. Sort of looks like it's coming from the breather but kind of not.
Clean it and see where the leak is originating.
76-914
Aug 4 2014, 09:56 PM
Have you touched it. Looks like some stuff I had on a trans but it wasn't a leak.
rjames
Aug 5 2014, 01:45 AM
A lot of it looks like paint. Clean it up and see what's left.
JB620
Aug 5 2014, 11:08 AM
Ok sounds good, I'll try that first before completely freaking out.
JB620
Aug 5 2014, 01:33 PM
Ok, cleaned it up a bit- as much as I could reach squeezing up and under the back end. What should I use to get into the smaller surfaces?
flash914
Aug 6 2014, 10:48 AM
Check the oil levels Engine and transmission and go drive it to see if it comes back.
Gordon
Aug 6 2014, 11:11 AM
Brake cleaner works wonder for cleaning that stuff ...
Cap'n Krusty
Aug 6 2014, 11:55 AM
QUOTE(JB620 @ Aug 5 2014, 10:08 AM)
If you're gonna completely freak out anyway, just do it now and get it over with ................
The Cap'n
JamesM
Aug 6 2014, 04:02 PM
Is it up on the underside of the trunk floor as well? Based on where it is being thrown, i would guess gear oil leaking on to and being thrown from the CV, and then baked on from exhaust heat.
Dr Evil
Aug 6 2014, 04:07 PM
That thick black stuff is not gear oil. Its tar or undercoating someone sprayed. It could be asphalt resurfacer. I see it on many transmissions, but that is not associated with a specific leak pattern.
Leaking stuff is what you should be interested in. Follow leak. Check levels.
stugray
Aug 6 2014, 06:24 PM
QUOTE(JB620 @ Aug 5 2014, 01:33 PM)
UH OH!!! You made a clean spot! Now youre going to have to do the whole thing or THAT will drive you crazy.....
Jeff Hail
Aug 6 2014, 08:54 PM
QUOTE(Cap'n Krusty @ Aug 6 2014, 10:55 AM)
The Cap'n
The Cap'n of the head demons has spoken. Sound therapy.
