I bought a 2.4L six about a year ago. It came out off a 72 T. I put it in my 914 got it running and took it to the dyno. I took the MFI off and put 40 webers on it. It made 160whp that seemed high to me for a 2.4. On my final pull the throttle stock when I put the clutch in. The adjusters pushed thru the rockers. So I decide to remove the engine. Well I pulled the heads off and found big domes on the pistons. Then I measured the bore and it came up 87.5mm. I looked in Bruce Anderson's book and found a engine listed in there with 87.5 pistons but with a 66mm stroke. Does any body know anything about these pistons? The are made by Mahle. Two of the cylinders need to be replaced. They broke between the head gasket ring and the inside bore. Any info would be great.
Blake
