speed metal army
Aug 8 2014, 07:20 PM
Advice please! I know its a17mm hex etc, its just being stubborn as hell!
bulitt
Aug 8 2014, 08:03 PM
Big heat!
injunmort
Aug 8 2014, 08:04 PM
I agree , if it is that stuck
speed metal army
Aug 8 2014, 08:36 PM
Heat the area surrounding the plug i assume?
injunmort
Aug 8 2014, 08:47 PM
right on the plug
Aug 8 2014, 08:57 PM
Lots of leverage
cpavlenko
Aug 8 2014, 09:04 PM
speed metal army
Aug 8 2014, 09:11 PM
On the plug? This would expand the plug..
But heck, if it works i'm in!
Mike Bellis
Aug 8 2014, 09:29 PM
Allen key, 2x4 to hold the key down, 2 ratchet straps to keep the 2x4 from moving, long pipe to add leverage to the key.
speed metal army
Aug 8 2014, 09:42 PM
QUOTE(Mike Bellis @ Aug 8 2014, 08:29 PM)
Im going to need a sketch for the 2x4 part of this..
02loftsmoor
Aug 8 2014, 09:51 PM
Wheaties
Elliot Cannon
Aug 8 2014, 10:07 PM
Heat the plug and the area around it. Then while wearing a thick pair of gloves, stick an ice cube inside the plug. Use a small cheater bar (length of pipe) on the allen wrench and give it a try. Think about it first. Visualize the plug loosening. Keep a positive frame of mind. If that doesn't work, a long chain of expletives sometimes helps.
speed metal army
Aug 8 2014, 10:14 PM
QUOTE(Elliot Cannon @ Aug 8 2014, 09:07 PM)
I like this one best..
Wish me luck!
bdstone914
Aug 8 2014, 10:15 PM
QUOTE(speed metal army @ Aug 8 2014, 08:42 PM)
I think he is saying to strap the 2 x 4 to the trans to hold in the allen key. It is a shallow plug and the key can twist out under heavy pressure.
speed metal army
Aug 8 2014, 10:18 PM
QUOTE(bdstone914 @ Aug 8 2014, 09:15 PM)
This makes sense! I actually thought he was fuch'n with me a little.
Chris H.
Aug 8 2014, 10:32 PM
QUOTE(Elliot Cannon @ Aug 8 2014, 11:07 PM)
Lawn chair...you forgot about the lawn chair.
seareef228
Aug 8 2014, 11:40 PM
pb blaster over night
then use square tubing or a floor jack handle for a breraker bar should work if you are simi strong
seareef228
Aug 8 2014, 11:46 PM
heat makes me nervous under a car but if you do, what you are doing is this,
heat it up right on the plug untill its red hot now heres the trick
wait for it to cool for about 30seconds to 1 min the plug first expands
then when it cools it contracts this is when you hit it hard
euro911
Aug 8 2014, 11:57 PM
Also, don't fiddle around with an inexpensive (cheep) Allen wrench. Spend a little extra $ for a 1/2" breaker bar and the special Allen wrench socket. Snap-On sells the socket.
seareef228
Aug 9 2014, 12:10 AM
QUOTE(euro911 @ Aug 8 2014, 10:57 PM)
Harpo
Aug 9 2014, 04:42 AM
I have the snap on socket if you want to borrow it
Jon H.
Aug 9 2014, 06:01 AM
QUOTE(Harpo @ Aug 9 2014, 02:42 AM)
I use the same socket with the impact gun and it works fine. Especially if the tranny is on the bench and you can't use leverage because the case is moving around.
Jon H.
ipadstott
Aug 9 2014, 12:06 PM
Every time I walked by mine I sprayed it with liquid wrench and gave it a try, after 2 days it broke free quite easy and I didn't over torque or break anything. I used the proper socket from snap on and you should to!
Ian Stott
Moncton
Canada
speed metal army
Aug 14 2014, 10:06 PM
Thanks for the advice and offers to lend me the correct socket!
Typical awesome 914 world stuff...
So... The reason I wanted to pull the plug (so to speak ) was to check fluid levels. My trans has been weeping out of the input shaft seal, so I figured it would be good to check. So I get the plug cracked open, moving along nicely.. I get to the point of finger tightness, continue backing it out. I get the plug out and and a 1/2 cup of trans oil spills on my gaddamned shoe!
It was wayyy too full. Its been this way since I bought the car in 2010 or so. Probably why it has been leaking..
Whatever, At least I'm not low on fluid!
stugray
Aug 14 2014, 11:17 PM
what? Howd the PO do that - fill it through the vent?
Or fill it while it was laying on its side?
Dave_Darling
Aug 15 2014, 01:06 AM
Fill it with the tail of the car up in the air...
(Don't ask how I know that...)
--DD
euro911
Aug 15 2014, 04:16 AM
Exactly how do you know that, Dave?
