I am replacing the o-ring and gasket on my taco plate. I have a 74 2.0L and I am having a tuff time finding the required torque value for the oil temp sender. Can anyone tell me what the sender needs to be torqued to? The only info I have found on the taco plate installation is the torque value for the two 6mm bolts that hold the plate to the case. I read that they need to be torqued to 9 ft/lbs, does that sound correct?
Thanks for the help!
Ray
