Full Version: Triad West
Triaddave
I recentely have the red car running again. went back to stock 2056cc with heat exchangers and 44 webers.
Question now is oil temp. I think i installed the wrong sender for the VDO. The gauge reads 250 degrees at hot. What is the normal running temp on our cars and how can I check the temp without removing the taco plate?. I tired a priometer and it read 160 degrees at the dipstict at 250+ at the guage. I am running Brad Penn start up oil, and do not want to drain until break in is done.......
jim_hoyland
I use the dip stick thermometer made by Mainlybydesign to verify...
See: http://www.mainelycustombydesign.com/engin...s.html#dipstick
Harpo
I spoke to the guy @ Mainely and he is no longer making the type 4 dip stick thermometer. What about putting a thermocouple down the dip stick tube to the exact same depth?
David
Jesco Reient
QUOTE(Triaddave @ Aug 10 2014, 03:12 PM) *
So the car is running cooler and happier now. Dave is smiling along the road!
RonnieJ
QUOTE(Harpo @ Aug 10 2014, 07:06 PM) *
David
He must have started making them again. I received mine last week.
