It's been a few years, finally got the MS wired up. 2056 with stock 2.0 intakes won't start, all I get is a few pops.
New Yellow top battery helped, the dead Red wouldn't even give me a pop.
EDIS-4 is working, great spark, and I can see the timing mark move when I change the settings in the laptop. (Had to rework the trigger wheel from McMark for the EDIS timing to work.)
New NAPA fuel pump and filter, new hoses, stock pressure relief valve.
Injectors are stock 1.8 with 1.8 resistor block, getting pulses to all of them.
WB EGA is connected to dash gauge, it was setup in air a while back.
Ideas?
I could use some eyes on the laptop, to give the settings a sanity check...
