You all have helped me out a ton so far. I've almost gotten my car running the way I want it. First of all, it should be noted that I have replaced all my vacuum lines. I have tried to test all the mechanical components, and I have yet to find my idling problem. I have NOT gotten my mixture tested by a CO analyzer. I have also had a shop clean my injectors. They said one of them has a lower flow rate than the other three, but it "should be okay".
Anyway, on to the problem. It idles too low when cold, and I don't know why. Let me describe what I know.
1. From dead cold (overnight), the car will immediately start, with an idle that barely registers on the tach.
2. When I give it a touch of gas, it will immediately idle at about 1,500 RPM.
3. After about 60 seconds, the idle drops to barely registering on the tach again. The car never dies, but it feels like it's about 50 RPM before it would.
4. As the car warms up, the idle will slowly rise to about 900 RPM.
5. When the car is hot (at least 15 minutes of running), the car will over-run if I turn it off as normal. However, if I turn the key off very slowly, it doesn't seem to do it.
6. When I re-start the car after a few minutes of sitting, the car will return to an extremely low idle until I get going a few miles down the road.
I have read thoroughly through PBanders D-Jet website, and I think I understand most of what's happening in the fuel injection. Most of what I've read says that vacuum leaks will cause a high idle, not a low idle. I guess I still need some guidance. Any ideas?
