QUOTE(scotty b @ Aug 12 2014, 04:47 PM)
QUOTE(76-914 @ Aug 12 2014, 04:06 PM)
HF has one that is <$25. All you need is a compressor, wet/dry disc and a bucket of soapy water. They work pretty damned well, also. BTW, get the good sanding products somewhere else. HF sand papers are crap!
That " kit " is a bunch of overpriced, un-needed stuff. I block most everything by hand then go back with a $40.00 Kobalt d/a with a soft pad on it and 2000 grit paper.
I was wondering when you were gonna chime in Scotty. I had never thought of using an orbital until I saw them do it, I always thought hand sanding was the way it was done. I can see where it would cut down time but I can also see where, if you're not careful, you could do damage!
