jacksun
Aug 13 2014, 10:53 AM
HI,
got the fuel pump and lines run in the engine bay,,, any complaints/tips?
also
the fuel tank strainer came with "B" are those to replace "A"??
why, is because A is somewhat flexible like a gasket where b is not.
Click to view attachment Click to view attachmentClick to view attachmenttks
randal
ChrisFoley
Aug 13 2014, 11:03 AM
I've never seen metal washers for the tank fittings.
The originals and the ones I sell are like a hard cardboard.
The metal ones will probably work. The assembly tolerances are fairly close.
CptTripps
Aug 13 2014, 11:15 AM
I used copper washers to replace the masonite ones when I rebuilt mine. I think you should be safe.
I also removed the strainer thing. Since I completely refinished the inside of the tank and put a real nice filter on the other side of it, I didn't see the point.
jacksun
Aug 13 2014, 12:24 PM
thanks for the replies...
I too have cleaned the inside and used a rust converter.
thanks again.
randal
Drums66
Aug 13 2014, 01:24 PM
.....To tell the truth........I throw the old stinky sock AWAY! ..&
use fuel filter's!!
(those,socks are easy to clog)
Elliot Cannon
Aug 13 2014, 01:42 PM
Teflon washers work.
Dave_Darling
Aug 13 2014, 06:03 PM
What is that fuel filter from? It's not the stock one that I know of...
--DD
bandjoey
Aug 13 2014, 07:21 PM
My strainer came with metal washers. And that's the fuel filter the local Porsche shops here sell. Forgot the brand.
ripper911
Aug 13 2014, 07:34 PM
Mahle-knect
rick 918-S
Aug 13 2014, 08:18 PM
I would use the sock if you have it. Fuel is dirty.
PanelBilly
Aug 13 2014, 09:58 PM
Your sock looks bigger than the one I got
914Mels
Aug 14 2014, 02:38 PM
I would keep the sock, you would be amazed what gets into gas tanks, it doesn't take much to block off the end of the copper tube and give you a mystery stalling problem.
rhodyguy
Aug 15 2014, 09:58 AM
With a cleaned up fuel delivery system I see no reason not to retain the tank strainer. First line of defense.
