spunone
Jan 24 2005, 09:45 AM
Ok whats the trick on removing the alum trim pieces on the rear of the top with out bending it ,I know you remove the screw on top but whats holding the bottom on.I guess you car it the roof pillar and I really don't need a new one at 200.00 bucks .Help
skline
Jan 24 2005, 09:47 AM
There is an 8mm nut holding it on at the bottom, you can access it from the wheel well.
SLITS
Jan 24 2005, 09:50 AM
QUOTE (skline @ Jan 24 2005, 08:47 AM) |
There is an 8mm nut holding it on at the bottom, you can access it from the wheel well. |
Sometimes
1/4" drive....universal joint.....long extension.....lotsa contorsion of the body and arms (your's not the car's)
skline
Jan 24 2005, 09:51 AM
Maybe this will help you too.
spunone
Jan 24 2005, 10:06 AM
Thanks did'nt know there was a nut holding it down Thats why I waited to ask this forum.Sure can save you money.Thanks again
Porsche Rescue
Jan 24 2005, 10:20 AM
Sometimes you can remove it without dealing with the nut at all. Use the palm of your hand and carefully press down and try to slide the trim to the rear (after removing the screw at the top). It will often slide off the clamp. It takes some effort since there is usually some putty between the clamp and the trim piece. I have done this several times.
Installation is the reverse.
