QUOTE(mskala @ Aug 15 2014, 11:50 AM)
I got a LeMans this year (early car, only need 1). For a small extra charge I
got the holes in the bolsters to allow the seat belts through. You can't see it,
but there is already a slot in the seat padding to let a sub belt through.
These 'fit' with the stock rails. However, not that I complained about it, but they
are a bit overstuffed, even the separate headrest, so if you are tall and need it
to fit into the backpad recess, better check into that. Also it is unavoidable that
the handbrake lever will rub on the seat, but it is in a soft area which will push
out of the way.
Bolsters are not ridiculously high, but you will need to learn to enjoy stepping
over to get in. Stefan said that his other models are more so.
the LeMans do bump into the backpad a bit and I'm only 5'7"....I have thought of just getting rid of the backpad altogether at some point though. I can't imagine folks with big butts being too comfortable in most aftermarket seats!
