aircooledboy
Jan 24 2005, 01:45 PM
Well,
Brad Mayeur called friday, and my taller trans is done.
Hi-evah, there was a small snag that you guys might want to know about. Brad called on monday, and said the used H gear he had that he was planning to use in my trany, he wasn't happy with.(What a guy
) Rather than have him use an H-B that he had, I told him to order an H, and I would pay the difference. Well, he found a good used H for 375, and put it in. But, when he went to find another used H for then next trans he was going to do,
no luck.
As of friday, the only H he could find was a new one for like $600.
Might be a temporary issue, but I thought I would let you guys know.
BTW, final bill for my trans: $914.43.
Looks like legit math on the bill too. No funny business just to make the total $914.
Joe Bob
Jan 24 2005, 02:03 PM
Guess I got lucky when I paid only 150.....two months ago....
bondo
Jan 24 2005, 02:16 PM
Damn, it seemed like a surplus of cheap ones when I was trying to sell mine.
aircooledboy
Jan 24 2005, 02:29 PM
QUOTE (bondo @ Jan 24 2005, 02:16 PM) |
Damn, it seemed like a surplus of cheap ones when I was trying to sell mine. |
Ain't that always the way.
Joe Bob
Jan 24 2005, 04:04 PM
Got mine from a shop that caters to the ass dragger crowd. Maybe they don't know what they are worth???
Mr.C
Jan 24 2005, 04:12 PM
Is the H gear in the sportomatic? If so what part number does it have?
rick 918-S
Jan 24 2005, 08:28 PM
aircooledboy
Jan 24 2005, 08:35 PM
QUOTE (Cabasa @ Jan 24 2005, 04:12 PM) |
Is the H gear in the sportomatic? If so what part number does it have? |
My completely uniformed opinion is no, they don't come from a Sporto. There weren't too many Sporto's out there, but there are many H gears, so it seems unlikely as the source. On the other hand, I know squat about trans questions.
I think I'll go back to drinking now. Is it REALLY only monday.
neo914-6
Jan 24 2005, 08:44 PM
QUOTE |
Is the H gear in the sportomatic? |
Check my tranny link in my signature...
0396
Jan 24 2005, 10:04 PM
Hey ,
I have a very good HA 2nd gear set.
What do you folks think it's worth?
ZachP
Jan 25 2005, 12:48 PM
I'm pretty sure you can find H as second gear in 901 four speeds..... Anyone know what the rpm/speed difference would be between H and HA in 914?
bondo
Jan 25 2005, 12:51 PM
I got both of my H gears out of 912 4 speeds. It's second gear in those. I think the transmission is technically called a 902.
marks914
Jan 25 2005, 03:36 PM
Good thing Brad did my tall gear swap a few months ago. Did he do the full gear swap and covert to a four speed for you? You will really love it. The full gear change really changed the way my car drives. The V8 is much happier.
-Mark
aircooledboy
Jan 25 2005, 05:16 PM
Yes, he did the whole "move 2nd to 4th, 4th to 3rd, 6th to reverse" or what ever the hell it was.
Truth is, I trust Brad implicitly, so when he said "this is what you should do", I said "ok, let me know when it is done."
BTW, in case you are wondering about the price, it was lower than expected, because the box had been serviced well recently. He didn't have to replace a single metal part other than the H.
jwalters
Jan 25 2005, 05:39 PM
OK--so now more indepth with this--swap waht gear to what position to get what ratio???
marks914
Jan 25 2005, 06:32 PM
here is the swap, I think
1st: not used
2nd still 2nd
3rd flipped 4th
4th flipped 3rd
5th flipped H
I have the gears listed at work, I will double check tomorrow.
Brad gave me a pretty good price too, only had to replace one bearing and the H gear. Plus he was able to drive a V8 car for his first before and after test of the gear swap.
--Mark
Chris914n6
Jan 25 2005, 07:07 PM
QUOTE (marks914 @ Jan 25 2005, 04:32 PM) |
1st: not used 2nd still 2nd 3rd flipped 4th 4th flipped 3rd 5th flipped H
--Mark |
Yep, that's it.
nicely spaced and good for waterpumpers over 200hp
jwalters
Jan 26 2005, 07:37 AM
QUOTE (marks914 @ Jan 25 2005, 07:32 PM) |
here is the swap, I think 1st: not used 2nd still 2nd 3rd flipped 4th 4th flipped 3rd 5th flipped H I have the gears listed at work, I will double check tomorrow. Brad gave me a pretty good price too, only had to replace one bearing and the H gear. Plus he was able to drive a V8 car for his first before and after test of the gear swap.
--Mark |
Thanks man---let me know those gear numbers please. J.
marks914
Jan 26 2005, 05:32 PM
Here they are...
aircooledboy
Jan 26 2005, 06:08 PM
WOW!!!!
Great chart Mark. Thanks.
jwalters
Jan 26 2005, 06:28 PM
Very nice chart !!!!--which gears are the 32:19???
Are those the higher gearsets everybody is talking about??
And what you are doing is taking the respective gears off thier respective shaft and putting them on the other shaft??? Ok, I think I got it now.....or do I??
jwalters
Jan 26 2005, 06:46 PM
Ok--I am officially dislexic--I have all three trannies on the floor---for the side shift models--explain to me what detents have it in what gear---
ex: pulled away from case and moved fwd is what gear
pulled out from case and moved back is what gear..etc, etc,
I keep looking at the rod coming outta the car and am seeing stars trying to " see" the rod movement in the tranny shift housing---
Would you believe I work on jet aircraft for a living??
dwillouby
Jan 26 2005, 07:06 PM
Im confused, I thought you replace 5th with the H gear set, Put the 5th set in place of 4th, and put 4th in place of 3rd?
David
bondo
Jan 26 2005, 07:12 PM
That's what I'm doing. It's more complicated than just moving it though. 2 and 3 have the slider (and dog teeth, syncros, etc. on one shaft, 4 and 5 have it on the other. Whenever you move a gearset from a 2/3 spot to a 4/5 spot, you HAVE to flip it to get it to fit. (By flip I mean whetever gear was on the mainshaft goes on the pinion shaft instead, and vice versa) This reverses the ratio of the gears. (a 19:32 2nd gear becomes a 32:19 5th gear)
jwalters
Jan 26 2005, 07:22 PM
QUOTE (bondo @ Jan 26 2005, 08:12 PM) |
That's what I'm doing. It's more complicated than just moving it though. 2 and 3 have the slider (and dog teeth, syncros, etc. on one shaft, 4 and 5 have it on the other. Whenever you move a gearset from a 2/3 spot to a 4/5 spot, you HAVE to flip it to get it to fit. (By flip I mean whetever gear was on the mainshaft goes on the pinion shaft instead, and vice versa) This reverses the ratio of the gears. (a 19:32 2nd gear becomes a 32:19 5th gear) |
OH MAN--NOW I AM REALLY CONFUSED---
my book lists second as 34:18---and is not one of the gears for second cut from the shaft itself??
I need another beer-- ( Big Sigh )
marks914
Jan 27 2005, 05:49 AM
OK here is how it works:
2nd gear is fixed on the shaft, it stays what it is. 5th is replaced with a flipped H gear. If you move 4th to 3rd, it is too tall, that is why you use the flipped N.
If you need to know what gear is what on the shaft, look at the haynes manual, it has a cutaway.
Mark
bondo
Jan 27 2005, 10:38 AM
QUOTE (jwalters @ Jan 26 2005, 06:22 PM) |
OH MAN--NOW I AM REALLY CONFUSED--- my book lists second as 34:18---and is not one of the gears for second cut from the shaft itself??
I need another beer-- ( Big Sigh ) |
Sorry, bad example.. in the 914 trans, second is unmovable for that reason. The 912 4 speed trans has first as the unmovable gear, and second is the H gear. So putting the H gear in the 5th spot requires you to flip it, giving the desired 5th gear ratio.
jwalters
Jan 27 2005, 12:23 PM
QUOTE (bondo @ Jan 27 2005, 11:38 AM) |
QUOTE (jwalters @ Jan 26 2005, 06:22 PM) | OH MAN--NOW I AM REALLY CONFUSED--- my book lists second as 34:18---and is not one of the gears for second cut from the shaft itself??
Sorry, bad example.. in the 914 trans, second is unmovable for that reason. The 912 4 speed trans has first as the unmovable gear, and second is the H gear. So putting the H gear in the 5th spot requires you to flip it, giving the desired 5th gear ratio. |
Ohhhhh- so I would need an H gear from a four speed-----now it is all starting to make sense.....
Aaron Cox
Jan 27 2005, 03:28 PM
so it drops 5th gear rpm by about a 1000
hmmm... with my 50 series azenis...this could be good. that and a flipped 3rd with an H for 5th
marks914
Jan 28 2005, 04:49 AM
The rpm drops 700 rpms in the new top gear from stock (ZD?) gear.
Mark
dwillouby
Feb 1 2005, 08:43 PM
Sounds like I need to pull my trans. again and do the swap correctly.
David
redshift
Feb 1 2005, 09:06 PM
My V8 had a flipped H, but I never went that fast, don't regret that either.
M
BigD9146gt
Feb 1 2005, 09:18 PM
Heres a spread sheet i got from the bird site...
The HA second gear in 5th would be just a hair under a H gear in 5th.
I know GPR has a few used H's in stock
bondo
Feb 1 2005, 09:21 PM
QUOTE (BigD9146gt @ Feb 1 2005, 08:18 PM) |
Heres a speed sheet i got from the bird site... The HA second gear in 5th would be just a hair under a H gear in 5th. |
Did the HA come in any 4 speeds? If it's only from a 5 speed, then it will be part of the mainshaft and unusable for 5th.
redshift
Feb 1 2005, 09:29 PM
Hmm.... it's out there as a single gear, just finding good ones, and robbing banks for fun, and profit... and for the addiction..
I bet that one is hard to find.
M
ZachP
Feb 2 2005, 01:25 AM
HA didn't come in 4 speed 901s. But I think it was offered as an option for 911S from 1968 until 1970. Can anyone confirm or correct this? That same tranmission was also used in a few circuit races. H, however, was used for 2nd in 4 speeds. Didn't the sportomatic have an HB or something like that? Or Did that also use HA?
redshift
Feb 2 2005, 01:38 AM
Welp....
http://members.rennlist.com/chuxter/901&915ratios.htmSee, the problem is, you won't find it in a 901, 911, 914, or 915 box....
Hey, 7:27 r&p? Anyone have that?
M
ClayPerrine
Feb 2 2005, 07:33 AM
QUOTE (Russian019 @ Feb 2 2005, 01:25 AM) |
HA didn't come in 4 speed 901s. But I think it was offered as an option for 911S from 1968 until 1970. Can anyone confirm or correct this? That same tranmission was also used in a few circuit races. H, however, was used for 2nd in 4 speeds. Didn't the sportomatic have an HB or something like that? Or Did that also use HA? |
901/00 4 speed has an HB second. I know, I just pulled mine apart last night. The H second is from the Sportomatic.
On topic, If anyone is building a V-8 and is locking out 1st, why not do it right. Get the reverse gear setup from a 901 4 speed. I have one if anyone wants to buy it.
NO, the HB gear set is not for sale. It's going in my car for 5th.
bondo
Feb 2 2005, 09:28 AM
QUOTE (ClayPerrine @ Feb 2 2005, 06:33 AM) |
NO, the HB gear set is not for sale. It's going in my car for 5th. |
What year is that 4 speed from? I pulled apart 2 4 speeds from mid 60s 912s, and they both had H seconds. I'm not sure the 4 speed reverse stuff will fit on a 5 speed without using the mainshaft from a 4 speed.. maybe it will, I haven't tried it. Using a 4 speed mainshaft would be bad though, as the first gear ratio would be way too low.
skline
Feb 2 2005, 09:35 AM
QUOTE (bondo @ Feb 2 2005, 07:28 AM) |
QUOTE (ClayPerrine @ Feb 2 2005, 06:33 AM) | 901/00 4 speed has an HB second. I know, I just pulled mine apart last night. The H second is from the Sportomatic.
What year is that 4 speed from? I pulled apart 2 4 speeds from mid 60s 912s, and they both had H seconds. I'm not sure the 4 speed reverse stuff will fit on a 5 speed without using the mainshaft from a 4 speed.. maybe it will, I haven't tried it. Using a 4 speed mainshaft would be bad though, as the first gear ratio would be way too low. |
I heard the 912 had the H gear in them also.
ClayPerrine
Feb 2 2005, 09:45 AM
901/00 from a 71 911 with a 4 speed. The mainshaft will interchange, just different gearing. I just took apart a 901/00 and a 911/14 last night. The only differnece in the mainshaft is the gear on them. The 901/00 has an A for the fixed gear, and the 911/14 has an F.
The reverse parts will fit on a 914 mainshaft.
It's possible that the 912 has an H for second.
Joe Bob
Feb 2 2005, 09:46 AM
Scott....I have that 901 trans sitting in the garage....H gear, Quaife LSD, billet intermediate plate and a fresh rebuild from Red Beard, still in the shrink wrap.....interested?
skline
Feb 2 2005, 10:21 AM
Of course I am interested, unfortunatly, my wallet says otherwise. I will have to wait and see what the tax man says.
Joe Bob
Feb 2 2005, 10:31 AM
Well it ain't going anywhere...seems like NO ONE has any money right now....including ME.
skline
Feb 2 2005, 10:37 AM
QUOTE (mikez @ Feb 2 2005, 08:31 AM) |
Well it ain't going anywhere...seems like NO ONE has any money right now....including ME. |
Yeah, I noticed all of your cars are for sale. If one sells, are you going to keep the rest?
Joe Bob
Feb 2 2005, 12:44 PM
selling two will help.....the Dakota and the V8 would be my choice...
