QUOTE(rosenfe @ Aug 16 2014, 09:17 PM)
QUOTE(PanelBilly @ Aug 16 2014, 05:49 PM)
Send it to Eric. Much simpler method and the results are guaranteed
i know i could send it to eric,its an extra 80 dollars,plus i want to rebuild my own caliper.his video is excellent.ill try easy out and drill
be careful, I did this a few months ago, here is what eric told me-you can leave it alone(mine were just rebuilt from PMB), it should still bleed out fine, and hold pressure fine. I messed mine up the easy out did not work and in the end I am not sure he was even able to save the caliper. cores are only worth 10-20$ so its not worth spending a lot on it if you mess it up. but if you are rebuilding it you may be able to back it out if you are really careful. good luck
Phil
