914itis
Aug 16 2014, 08:29 PM
I decided to install brad's outer long kit to stiffen my longs, what a great product ! The quality is near perfection.
Here te some pics.
Enjoy
partwerks
Aug 16 2014, 09:16 PM
I had them on my 3.6 conversion, before it got ripped off!
I'll see if I need them on the LS conversion or not. If so, I don't think I am going to use the part where you jack it up, just tote along a rolller jack.
GeorgeRud
Aug 17 2014, 10:31 AM
I have Brad's kit on my conversion car, and it really did stiffen up the car wonderfully. For the weight penalty, I think it's well worth it. Adding some inner longitudinal stiffeners (like the Engman kit) as well would be an excellent idea if you wanted to do an overkill stiffening of the chassis.
IronHillRestorations
Aug 17 2014, 02:00 PM
I cut little windows on the sill right above the vertical ribs and weld a bead there at the top
BIGKAT_83
Aug 17 2014, 04:40 PM
Thats the way to do it....
Bob
02loftsmoor
Aug 18 2014, 07:19 AM
does that just over lay ? just remove your rocker panels ??
914itis
Aug 18 2014, 07:45 AM
It lays over.
Steve
Aug 18 2014, 07:57 AM
It looks like you have to remove the ribs, that the hoses go through.
Do you also have to remove the jack mount or does it lay over it?
914itis
Aug 18 2014, 08:11 AM
Both mentioned ribs and jack mount comes off. The set comes with new jack post .
