Well, I've spent the last week poking, prodding, disassembling, eyeballing, and chin scratching, and have found out a few things.
First off, the engine is a very late 1974 2 liter (12th to last engine number for '74).
It runs!
It moves!
Most of the electrical items appear to function.
For those of you who have looked at the first set of photos I posted and thought, "He'll never be a REAL 914 owner if he doesn't have any rust to repair", I have removed the driver's side outer rocker panel and aluminum sill plate:
Now, on to the collision damage - I've removed the front lid, hinges, springs, washer bottle, and bumper:
It does not appear that the main damage extended beyond the first firewall:
However, the trailing edge of the compartment lid was mashed into the cowl at the outside corners. I think the cowl can be repaired in place:
Now, here are some photos of an issue that makes me a little nervous, but I'm hoping that once the bent metal is removed, the force it's exerting will be gone and the remaining metal will relax back into position. The driver's door fixed glass frame with the door closed:
The driver's door and fender panel gap:
The passenger's door and fender panel gap:
The damage seems to be pushing the left side of the car back and to the right, while pulling the right side of the car forward and to the left...
I don't have the donor car on site yet, so I'll be spending the next days continuing the disassembly process. Feel free to let me know how you would proceed it this circumstance!
Thanks,
Carl
