QUOTE(lsintampa @ Aug 18 2014, 02:22 PM)
So there is a tab that sticks out from the steering wheel hub. I assume it is meant to turn the signals off after you turn.
Since neither of my turn signals ever turn off, I'm thinking I don't have that tab in the correct location.
I think I put it at about 6 o'clock - not sure if that's correct or not????
I had the same issue. It was a PO thing. IIRC the tap should go the the same side as the blinkers..... maybe opposite...
You could probably figure it out. Look at what is left on the column when the wheel is off and see if you can tell what the tab hits to turn the blinkers off. Dry fit the wheel in different positions 'til it resets the blinker lever as you rotate the wheel back to straight, then move the tab and re-install the wheel.
Clark
