Hello Folks!
So, need more meat all around the car--2.7RS engine is way too much power to put down on the existing 205/50-15.
I am certain many of you have come to this point--need your advise in order to not reinvent the wheel (punt intended!)
Conditions:
1-want to keep existing 914-4 suspension, links, and brakes (actually, front brakes are fitted with BMW calipers; rears are still stock).
2-Planning to add spacers to the wheels in order to gain more space inside fenders (thus need to flare front and rear fenders; for certain rear fenders)
3-Want to keep same size tire all around; so I can rotate them.
OPEN FOR CHANGES:
A-Open to changing springs and shocks--please advise brand and rate of springs/suggestions
B-What size rims/brand or from what car (944 for example) could I get rims to fit 235?
225? what has worked for you? or I should avoid?
C- Can the existing 4 bolt pattern hubs be converted into a 5 lug pattern hub?
D- will add spacers to either 4 or 5 pattern as needed and add screw/bolt INSERTS
E-Should I keep the 4 bolt pattern over the 5 bolt pattern? cheaper rims in 4 configuration?
PS- I will be selling rims and tires once I get the above set up going; anyone has parts to exchange for what I trying to do, I am all ears!
Look forward to your inputs!
Regards
R8CER X
