hi,
I have been procrastinating doing this even though I have read pages of
"how to do" this valve adjustment. I decided to use the tech article pelican has
provided, at this link
http://www.pelicanparts.com/techarticles/9...alve_adjust.htm
so all I have done to this engine is to change out the push rod tube o rings and
then the tail cone gasket and the shift rod o ring and rubber bushing.
when I first removed the engine I did squirt some oil into the spark holes.
I could turn the impellor fan and the engine would turn as long as I felt like doing so.
now.
I have a hard time turning the engine by hand using the impellor fan. the spark plugs are out.
I was able to get "A" "B" and "c" to TDC for cylinder #1. I adjusted the valves to .006
and moved on to #2 which is where you see A,B,C current setting for.
if you look where #2 is positioned it is not TDC as the rockers are not "equal".
hopefully you will be able to straighten me out on this problem of mine.
tks
randal
