QUOTE(HalfMoon @ Aug 24 2014, 12:15 AM)
QUOTE(Dr Evil @ Aug 24 2014, 12:04 AM)
The leaks will be distinctly different between the two. A leak at 20 can not drip from the bottom of the shifter. It will drip off of the console housing at the lowest point, only.
A leak at 12 will drip off of the shift lever only and the console itself will be dry. Determine this first.
As for remove and replace of 12 while in the car, I would advise against it. Place a drain pan under the tranz, remove the two 13mm nuts, and with the transmission in neutral remove the console and let the oil drain out. You can try to drain it at the oil plug first (make sure the fill plug is able to be opened before draining anything!), but you will still get oil out when you pull the console.
After the console is removed you can then pull the rod out and remove the seal. If i havent already packed them all up, I will have a spare for you.
IF 20 is the culprit, you will need to investigate why it leaked. Look at the casting on the console for pores due to bad casting (happens). Look at the surface of the case where the O-ring sits. See if there is any left over sealant (not supposed to have been used). If you can not find an obvious reason for the leak, check the hole in the case for ovality. You may need to use a sparing amount of sealant on the O-ring if there is no obvious reason for it to leak.
Rats. I was afraid you'd say that. It's not leaking like a seive. Are you still gonna shine me on a fitted shift finger (not to be confused with a shit finger)? If so, mebbe I should just wait and do this seal repair at the same time, eh? If that's not in the relatively near future then I reckon I'd better go ahead and pull the console Monday for seal or o-ring repair, eh?
Poop. Always sumthin.
Btw, did you need any help with yer move? I got a truck and trailer that could be useful....
David
Man, I have 7 days off, non-contiguous, before I am to be out of my house. I am not doing a damn thing but tying things up. I dont plan to modify any more of those consoles until I am set up in the new house. Likely Nov at the earliest. Spent all of today doing a specialty build for a customer in Norway. What a PITA this one has been (build, not the customer).
So, I am guessing it is leaking from the O-ring?
