Here's a nearly complete fresh air system out of a 1973 car. Comes with both fresh air control/defrost valves, the interior diffusers and fasteners, the fresh air motor and box, the control panel, and all the control cables. The fresh air fan motor has been tested and working on all speeds. All clips for the control tubes are present. Parts not included are the fresh air intake grille and gasket, the air hoses, and misc. gaskets. The fresh air box is in overall good shape with both drain tubes intact, but some of the clip lugs that hold the two halves of the box together are broken (still enough tabs left to hold the box together!). One of the air control valves has one tab broken off. One of the two metal inserts in the fresh air box has come out because the plastic is split, but is still present and the box can be glued back together. SOLD! via eBay.
thanks,
Carl
