My speedo was reading 10 - 15 mph under true speed. So when the speedo read 65 mph I was really going 75+. This was verified with the GPS . At 40 mph, both speedo and GPS were close; the faster I went, the greater the error.
Last week the speedo was sent to North Hollywood Speedometer for calibration. Today they called and said he speedo works fine and requires no adjustment. They suggest that the problem is related to the cable. I had borrowed a second speedo from a member here and tested it while mine was at NHS. The tests with the loaner were good, a small error due to tire size. It read about 4 - 5 mph faster than actual at 65 mph.
I'm thinking the speedometer cable is slipping causing the gauge to under read at speed....????
I was wondering whether any one else has experienced this.
***Update: NHS opened up the speedo and found The jewel support which secures the speedcup to which the pointer attaches was worn
