1976 2.0 FI
Runs great, hunts a little (from 700 to 900 rpm) at warm idle.
Coming to a stop, the RPMs drop from the running rate (3,500) to a single bounce around 2,000 rpm, and then drop to almost a stall before coming back up to 800.
Thinking the decel valve may need to be adjusted, I pulled it out and put a vacuum on the control (small) port. I can put 27 in-Hg vacuum, and the valve doesn't open. I have loosened the lock nut, and turned the adjuster, but it doesn't do anything. Hit it with PB Blaster, but can't seen to get anything moving inside.
Anybody ever had this issue? Resolution?
Would this cause my idle drop issue, or is it something else?
Thanks.
