dcecc1968
Aug 26 2014, 01:03 PM
I assume the oil light comes on when the oil level gets low, thus the light comes on for a few seconds after cornering hard, then goes off. Just want some affirmation from the group if this is correct.
Thanks,
Don
Bruce Hinds
Aug 26 2014, 01:33 PM
It's a pressure light, it comes on when the pressure is low, not necesarly the level. If you corner hard enough to uncover the pump it will come on.
SLITS
Aug 26 2014, 02:25 PM
Your pump is sucking air. The centrifugal force in a hard corner will move the oil to one side of the engine away from the pickup tube.
Cure .... slow down in corners
or
add a deep sump
or
try running the engine about 1/2 quart over full on the stick
or
dry sump the engine
or
install an accumulator
Dave_Darling
Aug 26 2014, 03:19 PM
Have you checked the oil level? Many of us run a half-quart over, but if you're cornering hard enough, that is not enough to keep the light off.
I have a "tuna can" oil trap, and it has worked well for me. There are also larger deep sumps that can help. Or you can get an oil pressure accumulator like an Accusump. Or you can convert over to a full dry-sump setup.
--DD
dcecc1968
Aug 27 2014, 12:17 PM
Thanks Folks. That is exactly what I needed to know.
-Don
green914
Aug 27 2014, 03:29 PM
Had the same problem, and was fixed by running a half quart over.
