My daughter tried to crank the passenger side window this evening and the window won't crank at all. It's probably the same thing that happened a couple of weeks ago which I fixed by (and I'm probably going to botch the terms here) forcing the lifter back into the regulator. In layman's terms, the cable had come out of the guide, and I managed to force it back in which fixed the problem temporarily. I lubed up the components and thought I was good to go. This is an early window regulator ('72). I see references to Window Regulator Button when using The Google. Is that likely what's missing or needs to be repaired to keep the lifter from popping out of the regulator? I see AA has some, and I think 914Rubber, but I couldn't find the obvious part there.
That goodness this happened. I was sure I'd solved all the problems at this point and there was nothing left to do
