X911IC
Aug 26 2014, 06:58 PM
I have searched for a thread on how to install door handles, but unable to locate. When I install the handle, it does not seem deep enough to push the release tab. I don't see any adjustment. Need a little guidance. Thanks
914itis
Aug 26 2014, 08:04 PM
There is no adjustment. just slide it in, bolt it and it should work.
X911IC
Aug 27 2014, 06:47 PM
Paul, thanks for the heads up. After comparing both assemblies, it turns out out that one of the plastic clips the strikes the opening tab was broke off. Fortunately, I had a spare one from a parts car. Installed the new tab and everything works as it should. Easy fix once you know what to look for. Neil
URY914
Aug 27 2014, 07:27 PM
Send it my way when it breaks.
