QUOTE(Jetsetsurfshop @ Aug 31 2014, 08:15 PM)
It is lowered. Behaves badly under hard braking on the track. Bought a bump steer kit to help, then discovered there was one already there. Also noticed that the drivers shock has no travel, passenger one does, although limited. Ideas?
If the shock has no travel, then its either adjusted to heavy or something is wrong with it. Pull both and inspect. If adjustable adjust them similar. What is your suspension setup?
