QUOTE(stinkindiesel @ Sep 1 2014, 01:27 PM)
I've been in the same boat recently. Bowlsby's site is full of good info, but he only has 1970-71 1.7 and 1973 2.0 vacuum diagrams. Your 1973 1.7 is going to be somewhere in between.
In my 1973 1.7, for example, I found one of the vacuum hoses from the distributor vacuum advance goes to a short Y between the aux fuel regulator and the air box rather than directly to the air box as shown in the 70-71 diagram.
The 70-71 diagram is also missing the decel valve connections your car will have.
Wish I could tell you there was a diagram out there that would show you exactly how things were connected, hose lengths required, and how those hoses were routed, but there isn't. If my car was original enough to use as a template, I'd try to throw something together. As it is, I have some of the same questions you probably do.
Gary
That's not true. On a '73 1.7, the vacuum advance hose goes from the throttle body to the distributor, as does the retard hose. That tee on the AAR coupler attaches to a hose to the decel valve which is attached to one of the screws holding the MPS in place.
The Cap'n
