QUOTE(Cap'n Krusty @ Sep 4 2014, 04:05 PM)
If you mind the fins, you can easily pry the crank back through the timing hole.
The Cap'n
Engine is out, with all the tin.
I am seeing the assembly move forward according to the dial indicator, kinda stop, then with another taps with a hammer, move forward. From this position to the position i get when I either tap the fan back with a hammer handle, or via the pry with two screw drivers on the flywheel, i am getting 6 thousandths. Repeatedly. I think I am gonna go with this shim set.
