QUOTE(stugray @ Sep 3 2014, 08:42 PM)
A couple of ignition troubleshooting tricks I have learned:
To take the distributor out of the ignition picture:
Hook a plug wire directly into the coil HT socket.
Lay spark plug down on case, turn on ignition, and crank.
Do you get a spark?
Yes- then the points & coil are working.
No, then the points(/condensor) or coil are bad.
Hook the wire back to the distributor, hook the HT lead back to the coil.
Crank,
Do you get a spark?
Next test is the pertronix module directly:
unhook the black lead from the coil (-).
Hook a Multi-meter (in resistance mode) between the black wire and the case.
Turn the distributor (or crank it).
As the dist turns, you should see the resistance meter change from a high resistance to something much lower.
Dont worry if it doesnt seem to be dipping all the way to zero ohms.
if you turn the dist all the way around, and see 4 "dips", then the pertronix is likely working.
You can also put an idiot light (with a bulb) across the coil (-) to ground and crank it with everything hooked up normally.
The light should blink as you crank it.
(Dont try that with a multimeter or LED based noid light - you can fry it).
Thanks man!!
That helps a lot!
But, just to clarify. Are you saying use something like a test light from the - side of the coil to a ground like the battery ground? That should blink?
