This started right after i put in a full new tank of 93 octane ethanol free fuel-a day or so after, and the car did sit 2 days while we weer moving.
-hwere is why i think it might be the case. - car had run perfect all summer- even after sitting all winter while i did the 5 lug conversion etc etc. - i had put stabil in the tank and it was 1/2 full, and after sitting for months fired up first crank- since then and 2 other full tanks no issues at all- has run perfect, until the other day- on the way home after filling up i had felt a buck or two but those of us with d-jet will kind of ignor such things as they may happen on occasion but the 2 tanks i have run sinice it was ini the shop for valves set and timing its been awesome. and all this was done as a pre- tune before the Dragon run this month(octeenerfest)
its not- plugs, they are fine
not- points, i have Hot spark unit
not - wiring harness - thats all new last year-
- check the groundsand all connections to the distributor and coil. - good
- checked the fuel pressure- perfect(i have an in-line gauge)
so i put some fuel treatment in there and hope it does the job. - btw once the car was started i let it run for abot 20 minutes and it seemed to clear out somewhat. was idling o.k. , rand around the community , not over 35 mph, then parked it. --
---- what is your Favorite treatment for fuel? ive used lucas and Sea foam -
Phil
** update - even worse today really missing bad, now it might be looking like electrical spark, maybe hit spark module or injector triggers, or even coil? Will have to trouble shoot Saturday! Sure hope I can get it figured out before teener time next week!
