QUOTE(Jake Raby @ Sep 5 2014, 11:18 AM)
I do this measurement without the seal, so there's no chance of the values being impacted.. BUT if the seal depth is properly set the seal should not create any differences in the readings.
The 914 flywheel does have a raised center and IF the seal depth is not proper the seal will contact this raised center and will impact the end play values
There are at least 2 brands of seals that when properly seated protrude slightly from the engine case which would impact endplay values if endplay is measured with the seal installed. Like if you want to check endplay while you have the transmission out but don't need to replace the seal.
Examples of different seals:
http://www.gowesty.com/library_article.php?id=535I recall a thread where someone was having end play issues and Jake echoed this. But I don't remember what his advice was. I'm looking for the thread now.
