QUOTE(cwpeden @ Sep 7 2014, 02:03 AM)
I had the same thing and found the speedo drive gear poking out the tail of the trans. It was time to upgrade to side shift on the 72 anyways.
Nothing visually out of sorts from the outside.
QUOTE(Jon B @ Sep 7 2014, 12:47 AM)
If input shaft broke off at 1st gear, it would eliminate 1st and reverse.
Jon B.
QUOTE(Dr Evil @ Sep 7 2014, 08:24 AM)
With the end of the input shaft gone you still get the feeling of going into gear as the slider still moves fore and aft and still engages 1st big gear.
Westo2, do you get any feel of anything when shifting? If you do and no gear then Jon B nailed it.
QUOTE(Jon B @ Sep 7 2014, 06:23 PM)
Can't be sure that's what happened, but sounds likely given loss of reverse.
If it did, then broken shaft w/gear would fall to bottom of endcover, and could block movement of 1/R sleeve as well.
Jon B.
Yep - still feels like I'm engaging 1st and reverse through the shifter, but no go when I come off the clutch. I figured it had to be internal, as I also have no issues from 2nd to 5th, aside from a lower end whine/groan that I hadn't noticed below 3k RPMs (which may be more in my head than anything - I was hyper analyzing noises after the big bang).
If it is indeed the input shaft - what am I looking at for a job? Could it still be driven in this case, or is a chunk of the shaft likely rattling around in the transmission waiting to do more damage? Repair is much easier if I can get it to Syracuse and put it up on a lift rather than laying on my back in my driveway in Buffalo. I do have Dr. Evil's DVD - I suppose it's time to dust it off and start reviewing some notes. And - forgot an important point - dealing with a tailshift transmission.
Thanks all.
