If you think outside the box and are willing to go the extra mile, there are no cons to a twin plug T4.
All the standard ignition and tuning specifications you'll run across are out the window once the second plug adds another flame front. This can be a con, if you like things that are straight forward and "normal".
All of my engines that use a 100mm or larger bore get twin plugs (below this bore size efficiency from two flame fronts wasn't beneficial enough). I've never experienced a twin plug T4 that optimized with more than 22* full advance and often they'll like to run fully retarded initially with a very slow advance curve.
The engines will set up much leaner than most, most of mine run 11.5:1 or as much as 12.3:1 CR on pump gas and love it. Instead of a 12.5:1 Air/ fuel ratio being optimum, I usually find that twin plugs with my combinations will like 13.3-13.7:1 AFR to make peak BSFC and power/ cooling.
With all the details and variables mattering so much, I'd pick up the phone and call FAT and ask them. I have never seen a FAT twin plug engine, so I don't know what theory they build them from.
The twin plugs and two flame fronts change everything, in every way. My record is 284HP from a 2.9L T4 on 93 octane pump gas using twin plugs. That engine took 3 days on the dyno to optimize, because it had to tell me what it wanted and I had to listen. That one wanted less than 20* of full advance, which is less than I have ever experienced before.
Also, the ignition system matters a lot. I have staggered the advance/ retard between the upper and lower plugs and that makes a difference just like firing the plugs simultaneously sometimes matters. The real differences from this stand point comes from camber shape and volume, especially toward the bottom of the chamber where things are more inefficient by design.
What ignition system does it run? These are fun to tune, fun to own and are few and far between :-)
The gains in efficiency can be huge, once you acquire the magical tune and internal combinations.
3 liter twin plug street engine in the back of my Wife's 79 beetle cabriolet back in 2006. Made 249HP @ 5,500 RPM and 255 lb/ft of torque @ 3,000 RPM. Averaged 32 MPG (even with 51.5mm IDA carbs!) with head temps less than 300 degrees.
