QUOTE(Dr Evil @ Sep 7 2014, 08:31 AM)
Reverse should never crunch if clutch fully disengages. Unless it is crunching when you let off the clutch, then check external adjustments.
Clutch seems to be adjusted ok. Pedal has freeplay. I can go into second freely at rest.
But if reverse can not grunch then it must be clutch drag because reverse crunches same as first.
Everything else shifts fine
I'll double check clutch adjustment
