QUOTE(Larmo63 @ Sep 11 2014, 04:08 PM)
I'm installing stock sway bars front and back in a '73 914 and I'd like some recommendations on rubber vs urethane. Also,
are front and rear link bushings a different configuration? I don't want a squeaky ride. Thank you.
Front drop link bushings are rubber with steel inserts. The rear drop link bushings are a white plastic cup type. They don't squeak. I have seen the front bar bushings in Poly but I am not aware of anyone selling urethane sway bar drop link bushings. 914 Rubber sells the rear bar bushings.
I prefer the WeltMeister front drop link bushings as they are a two piece that makes installation easy. I would get the OE Porsche rear drop link bushings. They are a PITA to install. Uro also makes them but I have had fit problems with most of their bushings.
