Stock 72 1.7L D-Jet that is currently running well overall right now. But I have an odd issue where sometimes the idle will surge wildly when the engine is cold. It only occurs very inconsistently, but when it does, it happens the same way:
I start the car and it idles and runs fine as I'm heading to the end of my residential street (call it less than a 1/3 mile). While I'm going slowly in 2nd gear, the car will almost like clockwork buck once or twice. No big deal. When I get to the end of my street and stop at the intersection, the idle may suddenly start surging up to around 1800 RPM and immediately crash and surge up again. The car's probably only been running for about a minute or two at this point. Once I accelerate there are no symptoms or drivability issues, and after the car's been driven for a 4 or 5 minutes it doesn't seem to happen. It also only occurs MAYBE every other time I drive the car if even that. It only started about 3 weeks ago. I did replace the TPS Board roughly around that time.
I'm not 100% sure I calibrated the TPS correctly after installing the board. I followed the instructions on Pelican (if there is ANY ambiguity in any instruction I'm sure I'll find the way to screw it up). On step #5 of the instruction it says to "move switch CCW exactly one more hash mark." I assumed this means those little marks on both sides where the screws hold the switch in place. I don't want to focus totally on this as a likely culprit, but there does seem to be some correlation (time-wise) to this occurring and when I swapped out the TPS board.
Also, I do have a CHT spacer that helps with warm-up.
Any thoughts? I don't see a similar symptom mentioned on Anders' site.
In other exciting news, it appears I have been promoted on 914World - now that I have 50 posts it looks like I get TWO squares under my name
