Wondering what combination of head and cylinder base ring to use. I have 74 1.8 with the larger 96mm Keith Black pistons with standard 66mm crank stroke. AA cylinders. This engine is for street use and run on standard pump gas. I see most everybody recommends no more than 8.3:1cr.
Here are the compression number I can obtain.
With head gasket and cylinder base ring. 7.7:1 cr
With no head gasket with cylinder base ring. 8.2:1 cr
With no head gasket no cylinder base ring. 8.4:1 cr
With Head gasket and no cylinder base ring. 7.9:1 cr
Can I not use a cylinder base ring with out any problems?
What cam is being selected for this type 1911 66mm stroke 96mm cylinders and stock L-jet with a bit more compression and a larger cylinder diameter?
Thanks for your replies
