Yep, its all finished except the shroud install, and the carbs,etc!
I plan on getting it on the dyno on Friday!!!
Look here for some pics of the longbock and heads
http://www.aircooledtechnology.com/r_d_hybrid.htm
This engine has all sorts of wildness! It has an Ion Nitrided crank, ceramic lifters, phosphate and teflon coated bearings, Nickisil cylinders,Titanium pushrods Hybrid heads with DLC coated valves as well as many other DLC coated parts (basically every part that sees direct metal contact including rocker shafts, dizzy drive pinion, and etc
We took some big risks with one aspect of this combo by running a new ring package with the Nickies- We'll soon know how it works.
This engine is also the Dyno test pig for the 914 DTM as it will be installed in my 73, everything fitted and jigged in the car and then added to our production line up!
SOON! Hope to have some 200HP numbers to throw out on Friday!
