willimac
Sep 14 2014, 07:48 PM
I'll try to keep the story short. I have a '74 1.8 L-jetronic 914 that I rescued from a barn in central Wisconsin almost 3 years ago. It had sat for over 20 years and become a palace for generations of barn mice, who built nests in every available cavity. Since then I've been sporadically cleaning it up, vacuuming mice and their nesting material, dropping the engine, dismantling and rebuilding it, cleaning up rust, shopping new parts (alternator, starter, stainless fuel lines, seals and gaskets) re-boring the cylinders, splicing chewed-through wiring, etc... finally got it put back together this week and am having trouble with the fuel delivery. The fuel pump does not turn on.
There is power to the double relay switch - terminal 86a checks out with the ignition switch on start, zeros out in "on" position , and AFM resistance checks out. The terminals at the fuel pump plug read zero volts unless the ignition is turned to "start" and the AFM is propped open - in which case it reads 7 - 8 volts.
Don't know what to do---is there a way to test the pump to see if I need to replace it? Why would only 8 volts be making it to the terminals for the pump? Is this possibly a problem with the double relay switch?
Any help would be greatly appreciated...I feel very close to bringing this one back from the dead.
timothy_nd28
Sep 14 2014, 09:11 PM
Sounds like a weak ground
Chris Pincetich
Sep 14 2014, 10:24 PM
More tips/advice in this thread
http://www.914world.com/bbs2/index.php?showtopic=240820I am having fuel pump issues too
Also, I agree with the advice about improving the ground. My 914 ground post above the battery in back looked OK, but was actually lots of paint and rust. The cooling fan metal shroud/case is a good ground in the engine bay (my battery neg terminal is connected there).
Good luck
willimac
Sep 15 2014, 12:24 PM
Thanks for the speedy responses. So I cleaned up the ground strap from the battery nto the chassis, and the ground connection by the distributor cap (brown wire from the double relay) and tried again., measuring the voltage at the connector to the fuel pump. Same result - fuel pump gets about 8 volts initially. I let it crank a bit longer (a few seconds) and the voltage it was receiving began to drop. got down to about 5.5 volts before I released the ingnition.
and here's another strange thing that makes no sense to me: with the voltmeter hooked up to the fuel pump connector and the ingition turned off, the meter measures between .125 and .140 volts of juice. when I disconnect the Positive terminal of the battery, the voltage slowly counts down to 0.
I did install a new voltage regulator on the relay board, which looks quite different from the old one (not sure why I purchased it when I first started this project...Not sure whether the old one was good or not) Here's a pic of the new voltage regulator:
confused about what is happening here, and would love some ideas re:troubleshooting where the problem lies.
I'm on a steep learning curve when it comes to electrical components
Thanks so much!
timothy_nd28
Sep 15 2014, 12:48 PM
Ok, let's rule out a bad ground at the fuel pump connector. Keep the fuel pump plugged in, and active in the circuit. With your volt meter set at DC voltage, put one meter lead at the negative fuel pump connector. With the other meter lead, put that on the negative terminal at the battery.
Activate the fuel pump, or start the car and report back the voltage on the voltmeter, if any.
willimac
Sep 15 2014, 01:08 PM
Same result - starts at 8 volts and slowly decreases voltage
timothy_nd28
Sep 15 2014, 01:09 PM
From the fuel pump's ground wire to the negative battery post, you are reading 8volts?
willimac
Sep 15 2014, 01:18 PM
Yes. because the plug wouldnt allow me to get in there with the probe while it was plugged in, I jumped from the black/red wire female plug (the hot wire, as I understand it) to the positive terminal on the pump, then from the neg terminal on the pump, through the meter, to the neg post on battery. Reading was the same as when the test didn't go through the pump and just ran straight through the wiring (pos to neg on female plug connector)
timothy_nd28
Sep 15 2014, 01:35 PM
not quite what I had in mind but lets move on. What is the current battery voltage, measuring straight at the battery posts?
Also, is the fuel pump located in the front or rear of the car?
willimac
Sep 15 2014, 04:55 PM
QUOTE(timothy_nd28 @ Sep 15 2014, 02:35 PM)
Fuel Pump is in the rear, beneath the engine compartment, under the battery tray - voltage across battery posts is 12.32 volts.
timothy_nd28
Sep 15 2014, 05:05 PM
K, double check the voltage at 88d on the dual relay.
willimac
Sep 15 2014, 07:11 PM
QUOTE(timothy_nd28 @ Sep 15 2014, 06:05 PM)
I did this by clamping a jump wire on the back of the plastic plug, with the dual relay still attached. 88d is the black/red wire on the ignition harness, right? ran test from that wire, through meter to neg battery terminal
Voltage read 0 with ignition switch "on" and .03 to .04 with engine cranking.
timothy_nd28
Sep 15 2014, 07:56 PM
yep, the bigger black wire with red stripe is the fuel pump wire. So you have no voltage on pin 88D by either attempting to start the car or moving the AFM flap?
If this is the case, lets check the voltage at pin 88y. You should have a solid 12volts from this pin to the negative battery post. If you have 12 volts on pin 88y then continue with this step. Put the meter leads on pins 88y and 88d with the voltmeter set to DC. If you read anything between 0 and 12volts DC on the meter while starting the car, then you have a voltage drop across the points within the relay. 0 volts across these two pins indicates that you have zero loss across the points. 12volts would mean that the relay isn't pulling the points together
willimac
Sep 15 2014, 09:27 PM
QUOTE(timothy_nd28 @ Sep 15 2014, 08:56 PM)
Correct. No voltage at 88d moving AFM flap, .03 volts trying to start the engine (might as well be 0 volts, no?)
Yep, solid 12 volts at 88y, without the key in the ignition.
Solid 12 volts between 88y and 88d with ignition key off.
solid 12 volts with ignition key "on".
10.5 volts with the engine cranking.
So there is a voltage drop across the points within the relay. What does that mean?
BTW I am so glad that you chimed in on this post...I'm awestruck by how helpful you've been to others on the site, and have learned so much from reading those threads. THANK YOU.
timothy_nd28
Sep 15 2014, 09:43 PM
You're very welcome.
The voltage drop that you are describing indicates a failing relay. Overtime the metal parts inside the relay start to carbonize and become pitted, which increases the resistance across the internal switch, which robs power from the intended end product like your fuel pump.
A new relay will draw zero volts across the points when the relay is engaged. From the sounds of it, your relay is toast from either being internally pitted or corroded.
If you were to jump pin 88d of the dual relay straight to the positive battery post, does your fuel pump turn on then?
willimac
Sep 15 2014, 09:58 PM
QUOTE(timothy_nd28 @ Sep 15 2014, 10:43 PM)
No. there is a spark at the post when I connect the jump wire, but the pump does not turn on. (The last time the vehicle was licensed was in 1988, so the pump may be gummed up with old lacquered gasoline). Does it sound like I need a new relay and pump?
timothy_nd28
Sep 15 2014, 10:03 PM
Maybe both, could of been a domino effect. I'll have you do some more test tomorrow, I'm turning in for the night
willimac
Sep 16 2014, 11:12 AM
QUOTE(timothy_nd28 @ Sep 15 2014, 11:03 PM)
Thanks for the help...they only had one of the dual relays in stock at Pelican - I snatched it up - should be here Friday. Fingers crossed!
Dave_Darling
Sep 16 2014, 12:28 PM
Connect that jumper wire and measure voltage across the fuel pump wires. If it's +12V, that means the pump is getting power at that point and it not running is a defect in the pump. Probably gummed up with lacquer, as you said. You can clean them to some extent--the end cover is held on with four screws. Mark the end cover and the intermediate piece as well as the pump body so you can put it back together the same way it came apart, then you can remove the screws and clean up the rollers and rotor.
The rollers are little metal pucks, make sure not to lose them when you take the thing apart. If you can get them out (they're loose in there) and clean them and the rotor, then spin the rotor by hand, you'll at least have the mechanical parts of the pump freed up.
I don't think the O-rings are available, but you can supposedly find fuel-compatible ones that fit. But it's best not to damage them if you can manage it.
--DD
willimac
Sep 16 2014, 01:40 PM
QUOTE(Dave_Darling @ Sep 16 2014, 01:28 PM)
--DD
Thanks for chiming in, Dave. Voltage at the pump is about 8 volts, decreasing the longer the engine cranks. I'm hoping that a full 12 volts (which it will hopefully get with the new double relay) will kick it into action.
Chris Pincetich
Sep 16 2014, 01:46 PM
You could just wire the pump direct to the batter to test it. I've been driving like that for 2 weeks. It works, but is not a final solution.
willimac
Sep 16 2014, 03:52 PM
QUOTE(Chris Pincetich @ Sep 16 2014, 02:46 PM)
What gauge wire should I use if I were to try that?s
timothy_nd28
Sep 16 2014, 04:32 PM
Stranded 12 or 14 gauge would be fine, but I think we already established this test yesterday. Your fuel pump is indeed toast, and needs to be replaced. From the fuel pump being locked up, causes an high LRA condition, which could of fatigued the dual relay.
We never went into further testing with the dual relay, but having a new one is a great peace of mind if you plan on driving this car as a DD. I'm not much of a fan for rebuilding your own fuel pump. If not put back together properly, leaking fuel could occur, just not worth the risk IMO. One last step worth performing would be to remove the fuel pump and bench test it by connecting the wires of the fuel pump straight to the battery.
willimac
Sep 16 2014, 05:39 PM
QUOTE(timothy_nd28 @ Sep 16 2014, 05:32 PM)
It won't necessarily be a DD, but if I'm going to go to the trouble of taking it apart and re-assembling, I might as well do it right. Every system of the vehicle has been adversely affected by decades of neglect. Any thoughts on a good place to pick up a fuel pump? Pelican is sold out and Auto Atlanta has rebuilt ones for $236. Hoping not to have to spend so much.
Bob L.
Sep 16 2014, 06:12 PM
Start a WTB thread or search the for sale stuff in the classifieds. I've seen them available (used) recently. If I recall correctly, I got one for about $50. It was a 2 port.
Dave_Darling
Sep 16 2014, 06:25 PM
QUOTE(willimac @ Sep 16 2014, 12:40 PM)
8V should be more than enough to run the pump. I think yours is dead.
--DD
willimac
Sep 17 2014, 10:17 AM
UPDATE:
after much effort and frustration (mor on that later), I finally got the fuel pump out of the car - tried the bench test wiring the pump directly to the battery - nothing. took the pump apart per DD's instructions, and one of the little rollers was stuck in it's notch. I gently took a pliers to the rotor and pried it loose. applied voltage to the pump and viola! the pump runs! I reassembled the pump, and tightened the 4 screws -m tested again - nothing. Loosen the screws and the pump runs. I'll soak the components in some solvent to clean them up really well, and hopefully it'll work!
The downside is that I had to cut the bolts that secured the pump to the hellhole (wish I hadn't been lazy when the engine was out of the car) and I don't trust the metal that the pump was affixed to (esp the bottom bolt - compromised by hellhole rust.) I know I SHOULD take everything apart again and put the frame on a rotisserie and do it really RIGHT, but I really want to get this thing rolling under it's own power, and worry about the big restoration later. So - Question is this: if the pump cant currently go back to where it was placed at the factory, what's the next best option? would there be a problem with attaching it to the firewall (aside from it getting in the way next time I want to drop the engine? Where should I put the fuel pump if I cant get it to work under the battery tray?
dknechtly
Sep 17 2014, 01:16 PM
This is a good time to relocate it up under the fuel tank. You would get to it from under the car, with the protective pan off. It will help you avoid potential vapor lock issues.
willimac
Sep 20 2014, 06:51 PM
UPDATE: Original fuel pump is relocated to front, beneath fuel tank, behind access panel under front suspension. hasn't been bolted in place yet as I'm waiting for the rubber mounts. New (used) fuel pump here as back up. New relay switch installed. Fuel pump runs when jumping black/red wire at relay to battery + post. Pump ran for some time, expelling air bubbles into fuel tank, generating enough pressure to create a spray (atomized) leak at the supply side of the cold start valve, which was corrected by tightening the clamp. Engine cranks but still not starting, battery has run down with all the exercise - on charger now. fingers crossed. Thanks for all the help! I'm sure there'll be more troubleshooting to come.
