QUOTE(Jetsetsurfshop @ Sep 26 2014, 06:02 AM)
WOW, way faster then me. Very impressive in the brake zone. Still accelerating past the first set of brake cones in turn 7. Impressed.
I think I just have more experience with this car Shane. Much lower power and no slicks, which is I'm sure WAY different than driving your car. Remember you set a 3:20 really early on in your first stint. With less traffic and more time in the car, I'm sure you're faster. I've been watching your videos and it's good stuff - you're a good driver.
QUOTE(Seabird @ Sep 26 2014, 11:26 AM)
I get that same unloading of the rear in turn 15 also sometimes. I think, my case, its from over turning. Have you talked to anyone about this. I would like to learn more about how NOT to do this
its kind of unnerving when it does happen.
By the way the lighting looks great!
Miguel
Miguel - Shane and I put in 180 lb springs before the race to try to dial out any understeer on turn in and through the middle of the corner. If anything, I think it's perfect where it is. That unloading feeling is the rear end slowly stepping out as the outside tire reaches it's grip threshold, I think. Once I got a handle on it, it was a blast to drive and I could lay on (what little power) there was far before the apex. With a higher HP engine I'd probably step the spring rate down some, or in the best case scenario, put wider tires on it.
You just have to get used to the car being "twitchy". No sudden corrections and taking the correct line into the corner is paramount. In the case of my tank slapper, I was just carrying way too much speed for the angle I was trying to achieve. If I turned in a shade earlier, it made all the difference in the world and I could bleed speed off through the turn, rather than slamming on the brakes and killing momentum. Remember, as Harry Hogg said, "Loose is fast."
Did you drive the BMW at all? I hope to get on track with you at some point at a DE in the near future.
